'08 Parking Sensors (2 Viewers)
Cruiser Jimmy
Moderator
Western Slope, CO
So my parking sensor started to flash 'Check sensor' on thad dash. The two front sensor were being light up on the dash as the warning happened, not the rear.
I took the two front's out and replaced them with OEM new ones but I still get a warning.
For every search on YT, I get a video from Bangladesh that I can't understand.
Anyone have a problem with just front or rear replacement an they still don't work?
I would use Techstream to figure out which sensor is actually complaining. If you lost multiple at once, i'd suspect a wiring or ECU issue over an individual sensor failing. The connector for sensors in near the AC high pressure port in front of the radiator.
