'08-11 LX Spot Fogs in Bumper
TeCKis300
GOLD Star
San Diego
This mod is specific to the '08-11 LX. Fitting fogs in the faux air intake blanks.
The spot is pretty recessed with limited aperture. As such, I would probably limit the lighting type to spot or hyperspot beam patterns as anything else would likely waste light within the recess. Which is fine as the stock H11 fogs when upgraded with leds does a great job of shorter throw flood lighting even off to the sides. Separately, here's an OEM fog light mod to be able to run the fogs anytime, but also to have full headlight, highbeam, OEM foglight, and aftermarket spots on, all at once!
I personally choose Rigid D-Series Pro in Midnight Edition to keep it visually low profile. These are rated at 30 watts and 3168 lumens per light. Throwing 268m@1lux. These complement the stock high beams well as it's a beam pattern that's incrementally tighter, but throws farther. Any light fixture that is approximately 3" dimensions can work here. Like Baja Designs Squadrons could work too.
Onto the mod. I choose to work with the bumper on, and it's somewhat of a pain in the ass with limited access. May be easier for most to just take the bumper off. I only took the plastic undercover off that is between the metal skidplate and forward foot of the wheel well liner.
1) Remove faux blank in recess. This is held on by 1 philips screw from the inside, and 3 snaps
2) Cut snaps molded into the bumper. I used a dremel with a thin kerf cutter. Cuts like butter.
3) Make a bracket as depicted below make of 1" AL square tubing available at your local hardware store. 1.5" long is all that's needed
4) Drill holes in the bracket to fit screws. I used M8x16 screws
5) Setup Rigid brackets. I fitted them in reverse so they give a larger rise.
6) Mock up placement. The bracket can swing fore and aft. The Rigid Fig bracket has a slotted lower bracket to move left and right. Works well for adjustment and placement. Mark hole in crash bar.
7) Drill hole in crash bar to accommodate lower screw. I had a cheater right angle drill that could work through the limited opening.
8) Run electrical, final adjustment, and enjoy!
Hey brother! I absolutely love everything you’ve done to your rig! Question, as someone who doesn’t have access to 3D printing, is this project doable with a regular L bracket you think?
Thanks!
No 3D printing necessary. But there's some aluminum fabrication necessary to make a bracket will put the light where you want. It's a bit difficult to access and align which makes the job trickier.
Thanks!
Thanks for the input. May just do a fog light replacement. Having a hard time sourcing info for that bracket too. Seems to be the foot of my problems lol
Thanks for the documentation. Got some thrown in mine. They look a little off center from the front but they’re angled slightly outward, witness perfectly with the cutout and no wasted light trapped behind the bumper or anything. Maybe it’s just my mongoloidal hands, but kind of a finicky job. Happy with the result though.
Edit: used a stud bracket from Home Depot, the thing zinc ones used in house framing. Seems like it should be fine for now, if it needs re-doing, I may honestly consider having my fabricator make me something more specifically designed for this. A little 3D printing and a well designed metal bracket could make this a pretty easy upgrade.
Nicely done. Agree it's a bit finicky to get right. Once setup it works great like you said with no wasted light.
Make sure you have a gap between the bumper and the light fixture. Saying that as with all the off-roading and fireroads I run, mine just got knocked off its mount recently due to the bumper moving independently of the frame. The aluminum bracket I used fatigued and broke so I'll have remount mine.
Good call, I have it offset about a centimeter or so from the furthest rearward edge of those tabs for the insert that got removed. Hopefully enough for now, but as of yet, my run to the grocery store yesterday wasn't exactly a thorough shake-down lol. Thanks again!
