I didn't find anything when I searched the 100 and 120 forums so this may be a new one.
While getting ready to back out of my garage, I had my foot on the brake and noticed in my peripheral the bright red light from my brake lights reflecting off the wall suddenly turned off (but my foot was still on the brake). I pumped the brakes a few times and still no bright light.
At one of my stops on the way into work, I backed up to a wall of windows to see what was going on in the reflection. My lights all appear to work, my brake lights just don't go into high intensity mode. With the lights off, you see all the brake lights come on, just not brightly. With the lights on, you see a flicker as you tap the brake, but, because the intensity is the same as the standard tail lights, you really can't tell the brake lights are coming on. Thankfully the third taillight is still works, though also at a lower intensity.
If I put my Captain Obvious hat on, it appears there is a switch somewhere in the system that not only tells the brake lights to turn on, but also to be brighter than normal. That thing is apparently broken.
Anyone run into this before?
Random info for background: '06 LC w/ 102k, currently 18*F outside, no rain or moisture recently that would lead me to believe there is a moisture issue, when the LC is not being driven it's in a covered parking garage at work or in my garage.
