greetings y'all,
hoping the collective fellow cruiser heads could help me diagnose some issues.
issues:
- stop to drive. trans or driveline will thud significantly.
- 5th gear > 4th loss of 200 rpm. upon acceleration, the vehicle will downshift, then the rpm's will drop by 200 while accelerating only to re-gain the loss 200 rpm then shift back into 5th after incline/hill/acceleration.
- going from 4th gear to 3rd when trying to accelerate quickly I will notice the vehicle slamming into gear.
context/recent maintenance:
- hub flanges and CVs have been replaced within the past 50k miles with oem parts.
- past 2k miles front/rear drive shafts replaced.
- past 10k miles steering rack replaced by the Truck Shop in SD,CA.
- past 10k miles front diff bushings have been replaced.
- trans fluid level is acceptable and fluid looks clean.
- no current codes via scangauge.
- normal daily driver trans temp @ 130-150f. desert mountain pass temps (ambient temp 80-90f) trans temp @ 160-170f.
- vehicle mileage 256,xxx
thanks in advance for any advice and suggestions!
issues:
