Hi there,
I think my LX rear sits a bit high. Pictures taken are already in "N' position.
I also adjusted the Rear Height sensor and cleaned it and tested it
using the 3AA Battery test. Everything came out ok was was just off a little voltage.
As you can see the rear sensor is already adjusted to it's maximum
lowest position. (Next post)
There is another hole on the arm which I could transfer the link
that would make it lower. I'm just not sure if this 2nd hole is
really for that purpose.
Could this be a defective Rear Height sensor? It still moves up and
down when I adjust it. It's just that the "N" position it still too high.
Thanks in advance for your advice!
Francis
Francis
