00 LC Hundo (2 Viewers)
Got the ext sway bar end links installed.
Fronts looked pretty rough.
Rears weren't terrible.
Fronts installed.
Rears installed.
This was the last major thing to do for now. Time to set up a shakedown run!!!
~Ben
Took the LC out to Hidden Falls Adventure Park in Marble Falls. Met up with some other Toytoas and had a blast!
YT link for some clips
Cruiser did great. Had a squeak that sounded like a shield of some sort, but worked itself out and I didn't see anything when I got under there. Really looking forward to hitting some harder stuff on the next outing!
Added a little punch to the sound system. Picked up an Amazon special 8" powered subwoofer to put under the passenger seat where the factory amp went. Also took some time to clean up the wiring. It's not going to make any hair dance, but added just the right amount of bass to balance out the sound profile.
Latest round of updates! Prime Day got me and I just finished the install. Got a front bumper cooking too 😏
- SetPower PT45 fridge/freezer
- 600 watt pure sine inverter
- Blue Sea isolator
- 100 Amp breakers
- 100 Ah AGM
- Battery Box
- Samout fridge slide with cutting board
- 3/4" birch drawer (need to finish the actual drawer 😆)
Final workday before trip!
Got my front and rear bumper done at ATX Offroad (@atx_offroad on IG) and couldn't be happier.
Many thanks to TTTS&M (@AverageTanner) for helping with the winch wiring and wiring cleanup under the hood.
Eventful day before I leave...
Hundo died a couple miles from the house. Pulled the battery and Autozone tested bad, ok not so bad. Buy replacement and install, yay 12.3 volts. Drove home, volts no bueno. Alternator no bueno 😢
Back to the zone for the alt. Watch YT, try to remove, watch more YT, curse a lot, remove old alt. Yay... now reverse Tetris to get the MFer back in. More cursing. And we're in. Get everything tightened down and back together.
Crank it up and we got 14+ volts baby!!! Let's go... around the block. Felt a lil funny... then I looked down and behold, Xmas lights all over the dash. WTF 🤬
Scanner says cylinder #7 misfire 🙄
Grab my extra and pull the #7 coil and what do my wondering eyes do see, a crack the size of a Xmas tree.
Install new Denso coil, button her up and try again. Clear the codes and away we go. Fired right up, sounded 💯 better, took it around the block and man does it feel great.
This was day 0 of a 2200 mile trip. Leaving tomorrow!
Hundo did great in Moab! Hit Fins n Things and Hells Revenge. I did not attempt Hells Gate this trip.
Other than realizing a snorkel would have been great, trip was amazing. Here's some wheeling videos from the trip.
After I returned, got my results from last oil change from Blackstone. It got a clean bill of health. Spent a solid three hours cleaning the intake and replacing the air filter. Snorkel will be on the Xmas list 😆
Started hearing some popping and cracking driver front. Figured the cv was starting to go. Got the cv replaced and no more snap, crackle, pop.
They did a really good job on the bumpers. Love the tube style. Awesome build and thanks for sharing adventures. Fun to read this early monday haha
Learned a lot about Hundo since the last update and done a few things along the way. Mostly routine oil changes and fixing things here and there. Ive been enjoying just driving, ha. Heading to Utah with my two youngest kids early July.
Since the last update:
- Replaced the other CV
- Fan clutch (Aisin)
- Fluid change (oil, atf drain and replace, front/rear diff, transfer case)
- 4 Auxbeam spots
- Wireless switch panel
- Added fan to transmission cooler
- ~262k miles (owned ~15k)
Some pics since last update.
Decided to pull the trigger on solar.
- Renogy 120 watt ShadowFlux panel (16bb)
- Victron 15 amp 75 volt bluetooth solar charge controller
- Updated power box wiring
I decided to try locking pins on the front panel mount so I can rotate the panel when parked. My concern is the rattling when on trail.
Install was pretty easy and the Victron app is pretty slick and I've had everything connected for all of 2 hours... maybe LOL.
Obligatory pics:
Overall amazing trip with the kids from central Texas to New Mexico, Arizona, Utah, and Colorado and back!
- Four Corners Monument to Blanding
- Blanding to Manti-La Sal NF
- Elk Ridge Road to Briger Jack Road to Moab
- Rim Rocker Trail in Moab to Buckeye Reservoir
- Buckeye to Telluride
- Million Dollar Highway - Ouray to Silverton to Durango to Rio Grande NF
- Rio Grande NF to Pagosa Springs
Had some issues with the way I had the solar controller and wired with the ACR, field repair to make sure everything worked but I lost ability to monitor the overall load. I sorted that out as soon as I got home, but the solar was a great addition. Super happy with the performance. Didn't have any issues staying put and charging stuff and keeping the fridge going, even on overcast days.
Here are some pics from the trip!
Hundo got some new shoes and a new matching spare. Went with Falken Wildpeak MT 255/85/16 pizza cutters. So far I am thrilled with the on-road behavior. Road noise is fine, not must different than the 315/75 Ridge Grapplers that I can tell. I still haven't taken them off-road, but people seem to love em, so we'll see!
