1968 FJ40 For sale
1968 FJ40 Toyota Superwhite
This vehicle has no rust whatsoever, all rust was cut out and new metal welded in. I can send pics of underside, rear channel, floorboards etc.
307 chevy V8 out of chevelle, bored .030 over (312 cu in.) .500 lift cam
Edlebrock dual plane intake, HEI iginition, quadrajet carb
AA fenderwell headers w/3" exhaust that exits before rear tires on both sides
36" SuperSwamper TSLs 70% tread
sm465 4speed with 6.32 first gear
Stock 3speed tcase w/plate adapter
Tcase linkage all Toyota parts with 2wd low capability
Stock rear axle w/fine splines
Front axle stock fine spline and disk brakes and stronger truck birfs
New rotors, calipers, and pads
6pt roll cage w/4 overhead spreaders, dashbar and 1" tube gussets
Custom rear tire carrier holds 36" spare, hi lift, and jerrycan
and still see out of rear view mirror
4" Man-a-fre springs, 1.5" shackle in rear, Doestech shocks
Bed liner inside of tub
Custom body mounts made from Teflon w/ neoprene washers (1"bodylift)
Hardtop w/ working rear struts and handle/linkage
Bushwacker fenderflares
Factory rear heater
Jump seats w/ Toyota seat belts
Also new not mounted rear bench seat
There is probably more and I can send pics via email. Please only serious buyers. $9500 obo. I am in Madison Wisconsin
