Hello all, I am doing bit of work on my FJ40 and I am installing 4 point harnesses. I was going to weld in a cross bar to the roll cage's center hoop and I am tossing around a few ways of doing this and I would like your suggestion.
1: Just weld it directly to the cage
2: Weld on a flat piece of steel to both ends of the cross bar and then use u-bolts to attach it to the existing cage so that it can be removable.
(basically make a T on its side with U-bolt going through the center hoop and attaching to the top of the T)
Would option 2 be safe enough or should I just weld it right to the existing cage?
