David*BJ70
Looking forward to reach the end of the world
I wonder want is the maximum speed for shifting in 4wd without damage the t-case ?
cahilc said:You can do it but ...
Look at it this way.
If there is a mis-shift ... take you speed and *multiply* the damage by this factor to teh t-case.
This is why I shift when my truck is stopped. I like to multiply by "0".
To each their own,
Cahil
It is amazing what you can do if you understand things.lowenbrau said:I'm on the other side of the fence. If you are on a mountian pass that varies between dry and slippery ( very commont on a spring day) I'd rather shift back and forth at speed than just leave it in 4WD over the dry sections. I have shifted back and forth dozens of times ona single trip with out slowing down or pushing in the clutch. I have also had many t-cases apart and I understand what is going on in them.
60wag said:Although why anyone would want to put a part time 4wd vehicle in 4wd over 30mph, I don't understand but that's a whole 'nuther discussion.
brett76 said:so whats your max speed while driving around in 4 high?
Exactly,Mark W said:Me? depends on the conditions I am traveling in. Nothing to do with the drivetrain if that's what you mean. I've cruised the highway at 75 in 4wd pretty routinely.
Mark...
Mark W said:In the winter time I leave my hubs locked (basically from the beginning of November 'til the end April most years). Most of us do up here. I shift in and out of 4 wheel drive more times than I can remember everyday while at speed. For a 1985 vintage Cruiser (as the original poster lists in his sig) there is no speed limit. You could do it at 150mph if you can get your Cruiser moving that fast.
With manual hubs (locked) or driveplates, there is no "missing" of the shift to be concerned about and there is no damage potential. (You aren't really "shifting", rather you are just "locking".) Any other Cruiser with a manual activation of the T/C (not vacuum) and manual locking hubs (not auto) has the same "lack of issues"
As Bruce alludes to... If you understand how the T/C works you realize that there is no reason not to engage the front axle at speed.
Mark...
