wheelarches fix gone wild
buried in a pile of yota projects
I intended to start the repair on my truck for the re-inspection (sharp angles wouldn't pass) and got a bit carried away with the screwdriver :eek: I thought while I'm at it let's do the job nicely, since this is my show/business truck :D
The amazing thing is how perfect the roof is, and how bas the underside is. The previous repairs probably helped the cancer spread... This is how a mandatory fix turns into a resto job :rolleyes: I hope this will get this 02/1985 truck through 20 more years. :grinpimp:
pics
The filler neck is literally rusted through, I'm surprised it didn't leak a lot more. The place was filled with gunk, foam, cardoard, fiber... :eek: The filler neck and tank from my'88 are going in. When I have some time I'll slice the old tank to build a lower profile, smaller one.
holy crap, and i thought "ol Smokey" was bad!!
looks just like a CDM spec 70...
Man that does look like a lot of work. I must hand it to you, for spending the time on it. I just cut up an 85' BJ70 that from your pictures looked to be in better shape and I found that crusier to be a parts rig from day one.
Cheers,
Michael
Denis, not to be too blunt...but that body is beyond restoration...replacement is the only logical option. What exactly are you going to restore? By the time you cut away all the cancer, you'll have 1/3 of the body lying on the floor.
replacement ? bwahhahahahahahahahahahaha that's a good one ! you almost caught me :D
I'm fairly confident with this project, unfortunately I don't have the time to take the tub off to redo the body mounts but that will do it for now :grinpimp:
in my mind the best way to get to know your truck is to rebuild it. you will kow your 70 series much better than most by the time you are done.
keep up the hard work
cheers
cheers
Couldn't agree more! It's quality time well spent!
...digging out rust with a screwdriver is so easy to get carried away with. You start out small, with the intent on just 'exploring' the extent of rust, and by the end of the day you're ruthlessly hacking, pulling, cutting, picking, and you're truck looks even more like swiss cheese than when you started
