Some history. Three weeks after taking delivery I drove down to George. While playing in some building sand I noticed that the birfields are complaining when making sharp turns. (tuk tuk tuk) The very next week the OME kit was fitted and I drove around 500km with it (primarily in town). After completing the run in period I visited Atlantis dunes where the tuk tuk tuk sound became very evident and I decided to have the birfields changed. There is a slight noise on the clutch when the clutch is out (120 00km on the vehicle) and when changing the gears at hi revs the clutch gets very hard and stays on the floor for a few seconds after which it release and continues as if there is no problem. There is a slight silicon smell coming front the air vents.
After getting the vehicle back with the new birfields I heard the problem for the first time. While driving on the highway at around 120km/h one can hear a distinct whooooeeeeeeerrrrr sound. This sound is continues. At the same time one hear the occasional grrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr sound that typically lasts for up to 3 seconds. This sound is not easy to generate but is best experienced at 130km/h and when slacking down (running on engine compression). It could be associated with a bearing running dry type of sound. Some times it sounds like gwwwwwwwwwrrrrrrrrrrrr chirp and then the sound disappears. There is also a drive train vibration at 80km/h.
It took the vehicle to JB Auto’s but he could not experience the sound. We placed the vehicle on a vehicle stand (wheels) in the air and took it up to 130km/h while listening with a stetescope for noise. At 80km/h one could feel a vibration on the vehicle. The tranny rear output bearing sounded a bit ruff.
We decided to have the props balanced (front and rear). The U-joint where checked as well as the spline yoke and all was fine. After this the drive train vibration at 120km/h onwards was gone. Vibration at 80km/h remained as well as the gwrrrrr sound at speed. I noticed some wear patterns on the tyres and opted to bit new BFG AT 275x70R16’s. Thus it is not the tyres causing the problem. There is no loose exhaust pipe or heat shields etc.
We decided to have the rear and front output flange seals replaced. Rear was rather warn and noisy and the front was a little bit better but also replaced. Vibration at 80km/h is less severe but problem remains. Gwrrr sound remains.
My frustration is that I am throwing money at something but I do not know what the problem is. Also, the problem started after the new birfields were fitted and was definitely not there before. Wheel bearings are fine and were repacked 2000km ago with Omega57 grease. I just do not know where to from here.
Options:
1. Cry and pull my hair out.
2. Strip front diff and components and look for wear
3. Replace clutch
4. Fit OE suspension kit again
5. Cry and pull more my hair out.
6. What else.
Please help.
Options:
3. Replace clutch
6. What else.
Please help.
