So here is the scoop:
85 bj 70 3b with axt turbo, 9 psi boost
brand new 24"x19" 3 row double pass aluminum radiator with 16 lb cap
brand new toyota water pump
brand new thermo activated fan clutch
new hoses
new belt
new 82 degree celsius thermostat
new heater core.
autometer mechanical water temp gauge
autometer pyrometer with sensor mounted on exhaust below the wastegate.
KN air filter
Still the truck runs hot when pulling mountain passes at 50-60 miles per hour with the rpms at 2400
I am at a loss the truck hit 210 degrees farenheit on me and the thermostat equals about 180. at every other point than this situation it run at 160 degrees, 20 degree cooler than thermostat.
I do not lose any coolant or oil so I beleive the head and head gasket are fine. The EGT hits 1100-1200 degrees farenheit in the too hot situation. The only thing I can think of is it is getting too much fuel which is why it is getting too hot. I need help as I am stumped. Do I just need to slow down? You would think the truck could pull mountain passes at 50 mph Is it possible that the fan clutch is turning at high speeds and fighting the incoming air?
The only other thing I can think to do is turn the fuel down or get an electric fan as well.
Input is greatly appreciated.
new hoses
new belt
new heater core.
KN air filter
