Ok the wheels that I was supposed to get were not as described to me. Luckily no money lost but now I have wheels that have a back space 1/4" too shallow (3.75 back spacing). They clear the steering stuff but if a weight is added for balance, the weight will rub a bit. I could probably get by with the adhesive ones that do not go on the lip of the wheel. I have used wheel spacers in the past (quality ones that bolted to the studs then the wheel bolted to the spacer) but I don't need anything that deep. I just need 1/4". So to try it out, I pick up a 1/4" spacer and stuck it on. I still have the same amount of stud sticking out as my old wheels b/c they were thicker so that isn't a problem. But, what are your comments on using 1/4" spacers like these?
Of course they will be 6 lug.
