I am in the process of prepping the recently transplanted Utah rig for California smog (no wise cracks here ). So I have some questions:
-The OC Sensor connector: where is this located so I can run the test from the emission manual? (i don't want to tear up my bling carpeting if I don't have to)
-ACV inspection (pg 3-24 emissions manual): For the life of me, I can't get those big old hoses off for test. These are the big mothers. Any advice here other than cutting them off?
-HAC valve (pg 3-34 emissions manual): How do you get the top off to clean the filters inside? (same question for the Vacuum modulator).
-There is somekind of sensor located under the intake manifold, just aft (tward the rear) of the exaust pipe/exaust manifold connection. I couldn't find it in any of the manuals. Any ideas?
-The pointless pickup in the distributor has a black plastic cover. I can't measure the gap with the cover in place. How does one remove this cover?
-Idle speed adjusting screw and fast idle adjusting screw: I believe these are located the same side of the carburator and under the accelerator pump. The manual says to adjust with air filter in place. Well, the screws seem to be well hidden by the air filter housing. How do you guys get to these to adjust?
-Finally: Well, when I removed the airfilter housing to change out the carburator vacuum lines, I didn't take a picture of the vacuum tube routing on the distributor side of the engine. I though it was in the emmission manual, guess what? it isn't. Do any of you have the routing of the tubes (like a picture)? As an example: I know that one of the two tubes that goes to the distributor cap goes into the firewall. How about the other?
This is my first time digging into the 60's innards, so forgive any simplistic questions
