Thankyou again.
Having a deeper look into the local availability, it seems that there is an better availability of Mitsubishi turbo's and goodies here. Most have the funny OEM compressor housings but good solid TD4 cores are available. I have not seen too many AR values on the turbine housings but I am assuming the the 6cm and 7cm inlets say it all, and that i should go with the 6cm (lower AR, faster spool ) looking at my wishlist . Building off of a good core now makes sense to me as it leaves options all round.
As an opening bid, using my basic understandings so far say: TD04HL-19T. Lower AR turbine housing , lower ( 9??) turbine blade count, higher compressor blade count ( 11) still not sure about the compressor housing. Is anti surge even necessary in my application/ wheel choice. can it hurt to have it anyway ??
Stay with the lower AR's ??
shoot me down, i have a thick skin and am busy learning fast.
G
G
