Torque Spec Listing for 100 Series (2 Viewers)
OwnerCS
GOLD Star
USA
I see these torque spec lists around the net for Tundras and Tacomas. I know people who take the list and print it and get it laminated to keep in their tool box as a quick reference. I've printed these lists for when I have a large project going. I know this is in the manual. The compact organization makes it nice.
Does anyone here know if there is a list like this for a 99 model 100 series?
Impressive work!
The note in the upper left corner about torque values in FT LBS- maybe BOLD.
Since you've gone to the effort, if you want to get real fancy- highlight the most routine service items so its quick & easy to find stuff like drain plug values etc.
I dug up this quick service guide that might help to prioritize.
  • Service Data Sheet 2005 land cruiser 100_gasoline.pdf
@abuck99 Take a look at this version. I setup a section at the top for Quick Maintenance Reference Items. Then the items in that table are shaded in Lt. Blue cells in the respective section below.
  • Torque_Spec_Quick_Reference.pdf
Cool- nice work. 👍 👍 Maybe this will get added to the FAQ. You may also include wheel lug torque spec in the highlighted section.
Thank you. Everybody give it a look over. I just updated it again for the wheel lug specs. It's easy to update. I'm seeing things I didn't realize are different for a 100 series. I see wheel lug torque is 97 FT-LBS compared to 83 FT-LBS for a 6-lug Tacoma or Tundra. That was news to me.
