- Joined
- Jun 21, 2011
- Threads
- 225
- Messages
- 20,975
- Location
- Redding, California
- Website
- trail-tailor.com
This is my new 60 front production bumper.
The "ZERK"
I've had quite a bit of interest today and many questions on options and features. So from another post:
I've had 23 emails on the "ZERK" bumper, so a few notes to get out there for everyone.
§ Bare metal will not be a stocking offering. When I make a run of these I will hold one back at that time or will accept a custom order with appropriate lead times.
§ Construction Main shell- 3/16", frame brackets 1/2" winch tray 1/4"
§ Bullbar 2" OD x .188"
§ Weight - approx. 110#
§ Winch area 27" W x 7.5" D x unlimited tall
§ I designed this for the ComeUp winches. Up to a Seal Gen 2- 12.5# winch will fit. The integrated winch will work as well. Check your desired winch measurements, this is your responsibility. I don't have time to hunt and search for your winch dimensions. No a 8274 version will not be made.
§ Why a soft shackle recovery point? Safer, allows for tighter approach angle, lighter and a soft shackle doesn't clang around and damage powder coating/paint.
§ No I will not make a full catcher's mask grill guard. Why?... because I hate them and it will destroy the look of this bumper.
§ Black texture powder will be the color for stock bumpers. Custom colors can be ordered but only when a new batch is being made and sent to powder.
§ I can cut in wing lights (Baja Design Squadron Pro) on custom orders.
§ Yes, the wings have a webbed inner structure for added strength. Also the bottom lip is rolled/bent under 1.25" for extra strength.
§ There are 3 slotted holes for LED pods or a light bar.
§ I will have a pre-sell on the first batch on Nov. 16th.
§ Price-- I'll know more in a couple of weeks. Need time to make one from start to finish to get labor rates down, special shipping boxes, and exact powder pricing.
§ You must remove the factory bumper brackets and drill out frame rivets to install.
§ Yes, local pick up is available Mon- Friday 9am -2pm.
§ Yes, install will be available- 240.00 (no electrical included- that's on you)
§ Yes, grade 10.9 hardware will be included.
§ I will be making an aluminum version as well
§ I will be making a matching rear as well (in aluminum too- but no hitch receiver)
§ NO, NO, NO--- DIY KITS!!!
§ No, I will not make the fairlead opening for a WARN, Factor 55 or other. Not even on a custom basis.
§ The bottom of the bumper is 1/8" above the bottom of the frame.
§ Yes, this bumper works with the Trail Tailor front skid plate and Trail Tailor tow points.
Jason
The "ZERK"
Jason
