So I was cleaning the truck today and noticed a couple brown spots on the bottom of the tailgate... looks like a break in the paint and rust starting. What steps should I take to treat to keep it from expanding?
It really doesn't matter where the corrosion is. All treatment is the same. You have to strip the paint, grind, sand buff out, whatever, remove all the corrosion. Then you need to reseal the metal, I use either Ospho for steel, or Alodine for aluminum. If your doing the frame or any part that wont be seen, I would recommend Pore 15 on steel. Then Prime and paint. If your corrosion removal leaves a divot, then use either sandable primer, or some type of like Bondo product. I hate Bondo, but sometimes it has to be done.
