- Joined
- Dec 10, 2003
- Threads
- 36
- Messages
- 497
Background: My rig is a 76 40 series chassis with an 84 3B 5speed. It was completely rebuilt including sleeves when it got the diesel motor about 10 years ago. 6 Years ago it received a 2nd tank above the rear axle and a DIY vegetable oil switching system. It received a TD05-12B turbo from a volvo as well. I actually don't remember which of those projects came first. At any rate it has over 50k kms on grease and turbo. It ran around 14psi and never exceeded 600C on my pyro mounted pre-turbo.
I believe it got quite hot one time. At some point a year or two ago I found "trace" glycol in an oil test. It used approx. 250ml of coolant from the reservoir every couple thousand kms. The coolant in the reservoir was at times discolored to a weird brown/rust color. It still ran fine when I began this project but I expect I have a leaky head gasket or a cracked head. I'd always wanted an intercooler and to go back to the original air canister (from an open cone style air filter) and to add a snorkle. I also needed new fenders so some aluminum fenders are enroute. All this business, some new gaskets for other motor parts and new pre-cups will be performed.
Pictures to follow. Stay tuned if this is your brand of vodka.
