Hey guys,
Today i replaced the diaphragm in my B diesel. It was tricky to get too even with the EDIC motor removed. They cover plate still had lockwire on it, so i assume the diaphragm i took out was original. Anyway i replaced both my fuel filters at the same time. I primed the system and when i eventually got it fired up it seemed to idle a bit lower and smoother? The trouble i have now is i have basically no throttle. I can alter revs with the throttle, but when it is under load it dies. My garage is at the top of a hill and now i can't even get back up into the garage!
What do you think i have stuffed up? The diaphragm is obviously not holding vacuum i think. One thing i did notice is i don't remember seeing a seal come out when i removed the diaphragm cover. If the cover was not sealing to the housing, then that would explain it hey? I did put it back together without a seal, but i'm 99% sure thats how it came apart! Did i just answer my own question then?
Sounds like some sort of fuel restriction ... but then you've changed your fuel filters so that's unlikely.
