If you do indeed have a problem with air entering (as you suspect) Dan, when you get home I wouldn't expect you to be able to run your cruiser without bleeding it out first. (Or perhaps it may start and run briefly before stalling and refusing to restart without bleeding.)
I say this, because by the time you get home, the air would have had a lot of time to accumulate to "an engine-stalling quantity".
And I think the air is far more likely to enter from somewhere up high upstream of your fuel pump... like the bleed line running from your injectors back to the fuel pump inlet. This area will be sitting under significant vacuum now as the fuel wants to gravitate back into your tank.
On the other hand, your fuel-pump-inlet-strainer is down low enough that it is probably under a slight positive (ie above-atmospheric) pressure. (So fuel is likely to leak out there rather than air getting sucked in.)
The check valves in your fuel pump should hopefully prevent your fuel filters being subjected to vacuum.
When you fire it up, a slug of air will move into your injector pump and once there ....fuel injection will cease.
And if the bleed line is indeed leaking, the most likely place is that short length of small-bore rubber hose (and associated hose clips) at the top LH rear corner of your engine by your inlet manifold.
Cheers
Tom
PS. If your primer pump drips any fuel at all when you use it - replace it with a Bosch unit. (You can get one ex HongKong from Aussi eBay for $25 delivered ... last time I looked.)
And I'm going away for a few days without access to the Internet .................So I'll check how you're going when I get back.
Cheers
Tom
