Fitting power steering to my bj42 with a 3b but I don't have a pump or bracket, so I need some ideas of different options and pics
Cheers Dazz
Cheers Dazz
I'm also adding a power steering to my 3B. It's from a '91 Hilux. However, the wheel un the power steering pump is an 11 mm and the pulley wheels on the crank, alternator, etc. are 15 mm. Anyone have any idea how to match this?That's what I mean. I tried mounting an older altenator on the newer bracket or vice versa and it doesn't work. Seems to me that there was not enough movement of the altenator to get the belt tight.
Cheers Dazz
..... In addition, the belt is not long enought for the pulleys......Then I will look for the belt spec and buy one slightly longer.
Does your new belt allow enough movement to tension properly?
I'll answer ... probably. I make a complete restoration of my BJ42 and it can start it since the major component is not connected ... I'll know next spring.![]()
I believe there's a spacer in there somewhere, or the ac pulley acts as a spacer, something like that. I would be surprised if it didn't show up on the EPC.
David, your picture shows what I was saying earlier. Does your new belt allow enough movement to tension properly?
Any update? I'm working though a P/S install on my '82 BJ60 using OEM components.
It seems like the fan hits the idler but when I check the fan and fluid clutch are the same part number for both P/S equipped trucks and non-P/S equipped trucks. I know the original fan broke in Honduras when we did the frame swap so maybe the replacement fan is not the correct one though it fits fine.
