Hello allI'll start by stating that I have been having a few electrical problems which makes it hard for me to really diagnose my problem so I hope someone can possibly help. I just installed new brushes in my alternator and had to solder a few loose internal wires. It is back in the bj and I am not sure if I did a good job as I was only able to test the vehicle for about 2 min before it cut off. The multimeter showed a slow increase in voltage from just below 13V to 13.01 V. Since then, my starter decided to go out. I opened it up to discover a wire that should of been connected to a contact was loosly fitted over the cover and wrapped around one of the cover screws to make a ground, I guess. The contacts looked like new and the brushes were in good shape. I was un-able to open the opposite side of the starter using the 3 phillips head screws so I left it at that and put it all back together. Now that it is in, when I crank the key the starter responds immediatley, I can hear the plunger hit the flywheel? but it does not spin the engine. I did not test the starter before putting it back in as I did not know how. Can someone let me know how to do a bench test? Does this problem sound like only a starter? I have used a battery charger to do a slow charge overnight and get the same results. The battery voltage averages 12.96V. This is a 12V BJ40 with one battery.thanks
..... I know ---- I throw a whole pile of images from the FSM on here and perhaps they'll help us.
's new "freestanding cooker" installed in the kitchen today. It's presently "undergoing trials" and ponging out the whole house. (I never realised you had to "burn in" a new oven for an hour or two "to get rid of all the toxic fumes" before you start cooking your food in it.)
