Hi all,
Working through some oil leaks on the 2H. One leak is coming from the base of the centrifugal oil filter located directly above the standard oil filter. I've searched and cannot seem to find a source or number for this gasket. Should I just make one or can they be had from Toyota?
Another leak was coming from the oil pan drain plug. The threads on the oil pan have a rectangular section at the bottom where there are no threads. It looks oem but I'm not sure why this hole in the threads exists. The outer skin of the oil pan conforms to the area where the threads are missing creating a slight gap and thus, a leak. I used a punch from the inside to push the oil pan skin out and then hammered it flat. Now the drain plug mates up flush and no more leak. I feel like this will happen again over time. What is a permanent fix for this? Should I spot weld the gap in the threads or does that serve some purpose?
TIA
TIA
