- Joined
- Jul 20, 2004
- Threads
- 274
- Messages
- 23,204
- Location
- Chandler, AZ
- Website
- www.tontorecreationalliance.org
Did Brian's (Gus 96 FJ80) rig. His has J front and heavy rear.
Moved the rear holes in the bracket ~1/4" back and up ~3/8". Made a wood spacer to go between the arm and bracket, clamped the arm to the bracket and moved the holes. Installed the rear bolt, at the front, used a bolt as a jack, moved the front bushing so the inner steel bushing was flush with the bottom of the bracket and made new holes.
. If it is something that you are curious about, maybe Brian can stop by, toss it on the rack and do a caster sweep?
