How to Remove the Radiator - 1993 Land Cruiser
Wow.
That was about as fun as pulling teeth.
I have found that if you just buckle down and do these things in this order, things go pretty well. Maybe some of you will avoid the mistakes that I made on this job.
I got my radiator from eBay for about $127.00 with free shipping form this eBay store: http://stores.ebay.com/aeonimports
I have spent quite a few years as a mechanic and have seen a wide spectrum of quality in auto parts. The build quality on this radiator is decent, I would rate it a 7/10.
So here's MY suggestion on how to remove the radiator in your Land Cruiser
1. Remove the battery
2. remove the battery tray
3. Remove the front grille
4. Remove the 4 nuts holding the fan to the engine
5. Disconnect the upper radiator hose from the radiator, no need to remove the end attached to the engine
6. Remove the coolant reservoir
7. Remove the 2 bolts holding the fan shroud to the radiator
8. Disconnect the small skinny water bypass hose from the top of the radiator
9. Remove the fan and shroud from the engine bay.
10. Disconnect the two transmission lines from the radiator
11. Disconnect the lower radiator hose from the radiator and point it downwards into a bucket. I used a 5 gallon bucket. Some coolant will drain. About 2.5 gallons drained into my bucket while I was working.
12. Remove the two nuts that hold the radiator to the radiator support (area the headlights and radiator are mounted to). This can be done with a 12mm 1/4" drive socket with a flexible joint. No need to pull out the headlights.
13. Remove the two bolts that hold the "L" brackets on the sides of the radiator to the radiator support.
14. Remove the radiator from the engine bay.
15. Transfer the "L" brackets from the old radiator to the new radiator
16. Reassemble with new parts, fill with coolant, check transmission fluid level, etc...
At this point you may want to replace your belts for the water pump and AC compressor. They are easy to get at with the radiator out.
Make special note of POSITION of the transmission line fittings on your new radiator. If they are not pointed down as much as possible, the shroud will not want to sit in place, it will hit the transmission lines. The transmission lines thread onto the radiator, I would recommend attaching them AFTER you place the new radiator in its position to avoid banging them around, bending them or having them get caught on stuff while you're getting the radiator into position.
This is also a good time to replace the lower radiator hose if necessary.
I busted my radiator shroud in two places during removal because I thought I could get it out without pulling the battery tray. The shroud has at least a couple VERY weak areas. Honestly, the battery and tray comes out in 10 minutes, and then you don't have to spend a bunch of time repairing your shroud like I did. Having the battery tray out makes the whole job a LOT easier.
If you order a radiator online, beware of radiators that are thinner than the one you have. The core section on mine is 2" thick, it took a bit of hunting to find one that matched mine and was a good price.
Nothing about this job was hard, it just takes patience and some time.
Enjoy!
Feel free to let me know if I have left anything out and I will add it to the list. I was rather sleep-deprived as I wrote this.
Wow.
Enjoy!
