I made this rear bar over Christmas and figured some might like to read how I went about it and maybe inspire others to have a go. Like the front one I made earlier, this rear bar was a combination of what I wanted to achieve with the design regarding departure angle clearance, rear quarter protection and over all looks. I also took inspiration from other custom rear bars, many right here on IH8MUD
As always, even the best laid plans can change as a project evolves and this rear bar was no different. Here's some build pics (lots) and a bit of a description along the way...
Starting with a blank canvas
http://www.servimg.com/image_preview.php?i=418&u=14684539
I have a 25mm body lift and have lifted the long range tank to gain better departure clearance and thus lessen the chances of damage. I needed the underside of the rear bar to clear the top of the fuel tank so I tacked on 2pc of 30mm angle. This helped to support the rear bar during construction and ensured it went back into the same position each time.
http://www.servimg.com/image_preview.php?i=419&u=14684539
After much convincing from a guy I worked with, I got a packet of these silver pencils. Old mate was a fitter/machinist/welder from way back and totally raved about how good these pencils were to work with black steels. He was dead right, they are bloody awesome and $hit load more accurate, easier to see and longer lasting than chalk, pencil or texta. They're only about $10 for a pack of 3.
http://www.servimg.com/image_preview.php?i=420&u=14684539
A project like this that gets taken on and off so many times needs to have a reference point to build from. I marked the centre line of the chassis and took all measurements from that. Unfortunately, it may just highlight discrepancies in body panel alignment
http://www.servimg.com/image_preview.php?i=421&u=14684539
I also wanted to take advantage of the factory fixing points. Mine had rusted and the threads destroyed so I had to fix them. Cue two, 10x1.5mm x 40mm threaded rod couplers...
http://www.servimg.com/image_preview.php?i=422&u=14684539
Grind down for a friction fit onto the 20mm hole I drilled into the original fixing points...
http://www.servimg.com/image_preview.php?i=423&u=14684539
Bevel the outside edge for better weld performance and tap into position...
http://www.servimg.com/image_preview.php?i=424&u=14684539
Weld, grind and paint and you're good to go. Note: to protect the threads from weld splatter, I screwed in a old bolt covered in grease. The bolt got binned but the threads were as good as new. repeat process for all four holes.
http://www.servimg.com/image_preview.php?i=425&u=14684539
