I changed the oil on my 80 today and could not get the filter off. I tried two different filter wrenches and nothing. It's too tight t do the old jab a screwdriver into it and twist trick. I couldn't leave it where it was sitting, so I filled it back up with oil (7.5 quarts) and took it for a spin.
At idle, the pressure was about middle gauge. Under heavy acceleration, the pressure crept up to about 1/2 way between the upper middle line and the "H" line. This is much higher than I've seen prior to the change.
While trying to get the filter off, I put a small dent in the side of the filter, but there are no leaks anywhere.
Does anyone see any problems with this? The pressure is higher than normal, but not topping out the gauge. I have read other threads about the pressure showing really low at idle and coming up under acceleration. This is what mine did prior to this. I know I should get the filer changed out soon and I'll be looking for a new ratchet filter wrench later today. Can I change the filter with the engine full of oil? If a little leaks out, no problem, but I don't want to dump quarts of oil out when I pull the filter.
Help! I have to drive this thing 800 miles round trip to the beach later this week.
