Hi, we are talking about a 08/98 troop carrier.
Three of the passenger side rear axel studs have broken (again).
When I noticed this the remaining three nuts were less than finger tight, I have torqued them up to specifications (25 ft-lb, 340kg-cm, 33N-m) but am still not keen on driving it until I actually have the new hub and the six studs intact.
This is the third time I have had this problem, twice on the passengers side and once on the drivers side.
It has been variously diagnosed as bent axels and a damaged diff.
Hubs have been replaced twice(third to go in as soon as I get it)
Both the drivers side and the passengers side axels have bee replace – passengers side because it was (supposedly) bent and the drivers side because the tapered holes were worn / elongated.
The diff has been ‘straightened’.
Repairs have been done with both Toyota and aftermarket axels and hubs.
I am now thinking it is most likely to be a bent (or distorted) axel housing.
A complete axel assembly from a wrecker is about the same price as a bare axel housing from Toyota.
The complete unit from a wrecker might be a bit easier to fit BUT I have no idea how I could check it for distortion.
Anyone got any thoughts or suggestions?
Ray
Brisbane Qld Australia
Late 1998 HZJ75 troop carrier.
Ray
