Hi Folks,
I'm in the middle of rebuilding the 2F engine on my '83 FJ60 with 212,000 miles. I'm starting to get the feeling that its spinning out of control.
I have the block at the machine shop. We've already decided that I need a new cam (a decision confirmed when I posted pictures of the pitted cam lobes here). And either new or resurfaced lifters, though I don't know what the relative benefits of new vs. resurfaced might be other than cost.
I talked to the machinist and now he wants to bore the cylinders 0.5 mm over, which means I now need to buy new pistons and rings. He also says the crank shaft is at the lower end of the specs and wants to regrind, so I'll need oversize main and rod bearings as well.
He also wants to replace the timing gears and all new push rods. I don't think that all these things are in bad condition and it feels like were just replacing all these things to have them new for the sake of being new.
Or is it a good idea to just basically replace everything with an engine rebuild a 212,000 miles. It's just getting very expensive.
Finally, for ordering parts, do I order pistons, rings, and main and rod bearings at 0.5 mm over. And can oversize components be purchased as OEM or are they aftermarket components only.
Any guidance at this point would be appreciated.
Thanks,
Matt
Thanks,
Matt
