I post this in case it can help someone who is having similar issues....
So last weekend on my way home I discovered that my tail lights and rear markers were not working. Turn signals, hazards and brake lights were working, so I drove home with my hazards on. About 3km from home, my fuel gauge quit. I was worried because when it quit I didn't know if it was the gauge or all my fuel leaking out! I was driving on a fairly rough surface (packed ice on top or asphalt, but holes in the ice). I wondered if my diesel was foaming enough to make the float sink, as when I drove the truck the next day, it started out working again, then quit shortly after driving on the same road. Interestingly, my tail lights started working again.
My tail lights continued to work, and filled my tank full, so I could make it through last week. This weekend, I started poking in the suspected areas to see what I could find.
Fuel gauge was dead simple. I knew there was a short section of harness in behind the drivers side wheel well, so I started looking there. Bingo. Within seconds, I found the obvious problem. The pin on the red/yellow wire had corroded completely where it crimps to the wire. I left the good wire in the plug, and crimped on new heat shrink connectors on the other wire to bypass the bad side of the plug. Fixed, simple... Done. Fuel gauge is working again.
