5/84 FJ60. 197 thousand miles on the H42. Input shaft gasket, top cover gasket, and bearing retainer gasket are OEM replacements done at different times. Something from the front is leaking. Transmission is probably low on oil in this video but I don't think that would cause all of these different noises I am getting.
Noise occurs when clutch pedal is not depressed. Goes away when depressed.
On to my next question about my clutch components.
Should my 5/84 FJ60 have a spring on the clutch fork and back to the slave cylinder? Would missing one cause the throwout bearing to touch the pressure plate and make a noise like heard in the video?
I checked the 10/84-1/90 Chassis and Body Manual and it does not show one. So it sounds like I should have one.
Thanks guys!
Thanks guys!
