deciding if I should replace stock carb ? can someone let me know if they noticed a difference after installing new carb, will it give more power for pulling a boat. motor is stock
The common weber carb sold for Cruiser is a 38/38mm w/ 26/26 choke tubes (venturis to the rest of us).marko said:deciding if I should replace stock carb ? can someone let me know if they noticed a difference after installing new carb, will it give more power for pulling a boat. motor is stock
SDFJ60 said:
SDFJ60 said:I need to win the lottery!
SDFJ60 said:FOR REALS since I'd also like to get Kaymar stuff for the rear, OME suspension, 4.10 gears, H55F, and 33s eventually, what is that total, like 10K? hehehe
p.s. Thread Hijacked.
Steve-O said:Or you can get a kit that comes with everything and is gauranteed to work right. TBI Kit Steve.
When you replaced the carb, did you run into problems with the throttle linkage? What did you do to resolve this issue? I have just added the Weber 38mm and now the linkage is backward and the pedal is on the floor when the carb butterfly is closed. Hurting my brain right now trying to find the proper work around. Any help is appreciated.Hmmm,
I would beg to differ. I did the weber, and I have had absolutely no problems. My truck runs a lot better and gets a couple more miles to the gallon. As for more power pulling a boat--V8 swap ..
But for me, the Weber was a better solution than an new OEM carb, or a rebuilt. Lower cost quicker turn around. Since the Weber, I've passed every emissions test I've taken, and my truck's started every morning no matter how cold...
