All:
My FJ62 has the OME heavy/heavy kit, installed by me, and 33x1250's on Eagle Alloys. It also has new tie rod ends, new relay rod ends, a new tie rod and a new relay rod. I have also tightened the steering box. Still, it wanders a bit, especially on rutted roads. I have not added caster shims.
I have wondered for a long time why Toyota designed the relay rod with those spring-loaded ends. On my FJ62, I have those relay rod ends snugged down pretty tight in an attempt to eliminate the relay rod as a source of the steering wander.
But I'd like to run a relay rod with solid tie rod ends.
Has anyone with a spring-under suspension replaced their relay rod with something that does not have those springy ends? If so, how has it worked out, and where did you source it?
Thanks.
Thanks.
