Since my A/C doesn't work though the compressor does I decided to convert it to on board air.
Parts list:
Square D Pressure Switch, 90-125 psi Grainger #5A537
Air Pressure Gauge, 0-160 psi Grainger #1X754
Speedaire 4ZL57 Miniature Micromist Lubricator
Speedaire 4ZL08 General Purpose Miniature Air Line Filter
K&N Mini Air Cleaner
After receiving the Speedaire parts I found they were drop-shipped from Grainger so all parts could be ordered from them instead of 2 sources as I did.
When tank is added I'll be using these
Safety Valve, 150psi Grainger #5A709
Check Valve, 150psi Grainger #5X780
An assortment of 1/4" NPT brass fittings, clamps, hoses
This is converting the use of the stock Toyota compressor. I know many people prefer York but you can't beat the fact that it's already installed and mounted.
The pressure switch is the manifold, nice compact setup with 4 connections of which we used 1 for the output, 1 for input and 1 for the gauge. The 4th will be used when I add an air tank. It's attached to the firewall providing good access, switch wiring, ground and easy installation.
The oiler is in the input line to keep the compressor lubricated while the filter is in the output to remove water. These in an easily accessible spot along with the on/off switch which are all mounted by my air filter. The K&N mini filter is tucked away behind the windshield washer tank. Test running shows everything working perfectly and the pressure building surprisingly fast. Real use operation to come.
I think the pics show everything pretty clearly.
Parts list:
