On my '74 with all stock late F, I can be cruisin at 40/45 just fine and then if I slam the throttle to the floor it feels like an auto shifting down, not quite like bogging down, just takes a second before it revs. Could this be the same thing? And what is an accelerator pump?
The accelerator pump squishes raw gas into the carb to compensate for the full throttle you have just given it by mashing down on the pedal. You can check it by removing the air cleaner, so you can see down into the carb, I mean directly into the carb. You can manually actuate the linkage, or have someone push down on the throttle. NOW...this is all with the engine OFF! As you look down the throat of the carb, you should see a stream of gasoline in the primary side, the onw closest to the valve cover, BEFORE the butterfly opens. If you do not see a stream of gas, your ACCELERATOR pump is not working properly, and your carb needs to be rebuilt. Most kits come with exploded diagrams of the parts and if you use the Carb Dip, blow everything out, PinHead says rinse in lacquer thinner, and reassemble according to the diagram, you should be OK. The only adjustments are the float level,the idle mixture and the idle speed. The Idle mixture, a brass screw facing the valve cover at the base of the carb, screw in all the way and back it out 2-2 1/2 turns, then adjust in or out for maximum vacuum at about 700-800 rpm with the choke off.
What have you got to lose? It will not be any worse than you have right now. Jim Chenoweth is very helpful, and knows a lot more than I do, and is generous enough to share with us bone heads.
Get a good kit, Jim has VERY complete kits, a good place to work, don't drink until you're done, follow the kit instructions and VOILA! You can do this, young Luke,let the Force take over.
Ed
