Can anyone tell me what the toyota part nuber for a 64-66 FJ45 fuel tank is?
I should have it but I doubt it will do you any good. I will check my 65 FJ45 parts book tonight. I should ask which 45? If it's a pickup I should be able to help if a LV you might want to ask this question in the 45 section.
Here is the part number for the 65 FJ45LP-B gas tank 77001-90332.
my book's showing a break by frame number 77001-60030 up to frame number fj45-22535 and 77001-60031 up to frame number fj45-24185. 77001-60032 for frame numbers after that. book covers 65-67. the previous numbers may supercede directly to the last number
Thanks, mine is in the FJ45-21 Series and I am hoping that the part # will help me get some spects or visual representation so I can get one replicated.
Angelo
65 short and long used the same gas tank. I the same as the FJ40 of the same time. %ill neck is a little different. Could post pictures of the two side by side.
I installed the FJ40 tank yesterday. however, the tank sits 3/4" higher and 1/2" longer. this is not compatable with the customized seats that were installed before I got it. I can't put the pasenger seat back in. since I do not have a welder and stock,, I have to work on finding the original tank.I'll plagiarize, "Rocking Horse ****"
if you come across an early 40 series tank and filler neck, you can steal some material from the neck and slightly reduce it, than tig it to the tank filler to create parallel fillers requiring a straight, 40 series like rubber coupling. I've got one mocked up that I could take some pictures of if interested?
happy hunting![]()
Here is afew more. The 45 tank was in a 65 but not mine. Looka to be a replacement tank. Don't believe it came with any seats so I'm not sure if the two extra bumps it has on the top with fit with the stock 65 seats. I jsut know the owner was trading the tank to a guy for some 40 parts. Told him it wasn't correct for a FJ40 and traded the guy a 40 tank for his 45 tank which in in turn traded away. Everybody was happy.
