Now with install and pics! Split case 4:1, are these output gears bearing supported?
I need some insight here, I am in the middle of tearing down my split case to add the new AA 4:1 gears. I understand that the output shaft gears need to be bushing type and not run on bearings. Before I press everything off this output shaft, please take a look at the pics and tell me if you see what I see. I see these are bearing supported gears.
I do not know where this H55 and split case came from, I bought it like this. Because the work was done at Iron Pig Off Road I am going to assume it's from Oz. So I need to find a shaft from an FJ60, right?
