David*BJ70
Looking forward to reach the end of the world
It's time to soliciting your opinion. My idea is almost done, but another opinion, positive or negative, would be appreciated.
I swap OEM power steering gearbox unit on my 1982 BJ42.
I only have one steering shaft. The one from my actual unit without power steering... longuer than the power steering shaft assy. The other shaft was a regid shaft fram a 1979 FJ40. The mount one the fire wall are different.
I have to shorten it.
Picture above in the middle - I mesure the distance from the gearbox unit w/out power steering . (
Picture at the bottom - I mesure the distance from the gear box power steering w/power steering.
I plan to cut and weld it from 3cm.
Besides considering the angle of the shaft, did you have other recommendations
