I hope one of you carb gurus can help me out.
I have a 73 FJ40 that has a desmogged '77 2F engine with a '69 2bbl Aisan carb.
I'm trying to figure out if the desmog is set up correctly for this carb. I recently rebuilt it, but it is still running poorly.
The VSV is still in place, and there are four vacuum ports on the carb, 2 drivers side, two passenger side. (plus the PCV line from the insulator block). On the passenger side, one vacuum line from the throttle body goes to the distributer, the other is capped. On the drivers side, one vacuum line goes to the carb diaphragm and the other to the base of the throttle body. Both lines from the driver side of the carb are going into the VSV and there is another line from the manifold to the VSV.
Pics:
drivers side
passenger side
Does this look correct?
Pics:
drivers side
passenger side
