- Joined
- Jan 5, 2004
- Threads
- 143
- Messages
- 6,766
- Location
- Paint Lick, KY
- Website
- www.globalsoftware-inc.com
Here is a pic of my cleaned and blasted oil regulator. The piston or valve which ever you want to call it has some wear marks in it and was adjusted ALL the way in. I hear this part is no longer available? How about the internals? O ring? Valve? I could always hone the cylinder and valve but don't think that will help the oil pressure!
Should I start looking for a good used one or just shim this one and go?
Also thought some would like to see the PO ghetto fab on the oil lines to the filter. I was scared at first thinking the idiot had restricted the oil flow but after looking into the filter housing and seeing the tiny 3/32 hole I was no longer concerned. I am replacing these anyway as they are too short to properly clear the headers.
