OK, I did not want to mess up Bull's thread. Also this is not a John bashing, however he did post something that I wanted to address. I think it is important for people to see this. I know ATS might jump in as well. I would not do it unless I felt people should understand these things.
--- Original Post ------
A regular shock does not 'push' the axle down. Yes there is limited force, but the job of the shocks is to control the axle movement and dampen the springs. OME shocks have a bypass circuit, so if you press down on the shock very slowly you feel little resistance. The reason for this bypass circuit is to allow fluid to go past the valving when you do corrugated roads and not have every small bump transmitted into the truck.
The tire that is drooped out and the spring just about unloaded does not put pressure on the front. The tire that is compressed is that one that pushes the oposite front end down.
The only way that the drooped wheel is going to exert more pressure is if the spring is still compressed. With the L shocks at maximum droop the spring is uncompressed.
What does this mean?
Why would this happen ?
You are confussing the truck teetering on 3 wheels, vs 4 wheels on the ground with stability and forced articulation.
So previously the truck settled on the rear wheel and lifted the front. Now the axle is drooping a little more and keeping the truck from rocking back, hence your feeling more stable. Kinda like putting your finger out to stabilize you, not pushing with your whole arm.
If the axle was pushing, you would need more force on the spring, which means it should be less extended, which means the L shock is not totally extended. So, you would get the same effect with a shorter shock.
How does it do that?
ShottsUZJ100 said:Originally Posted by ShottsUZJ100
Adding the N74L shocks helps this "problem" as the added rear pressure on the rear wheel when flexed helped to put added pressure on the opposing front. This helped F&R in the articulation dept.
sleeoffroad said:Hijaak, how does the N74L put more pressure on the axle than the N74 when the are valved the same? The only thing that is happening is that the axle droops out more in the rear. It does not push the front down.
ShottsUZJ100 said:By keeping the rear wheel on and pushed against the ground rather than being in the air.
Of course if the holes get too deep and there's little to no force on the back wheel then the gain to the front is zero.
The front is so stiff near the bumpstop that it would push the front up and into the air.
With the longer rear shocks these scenarios have rarely showed. The rear's on the ground so the opposing front is on the ground.
Example pic. Before in this spot my pass front wheel would be off the ground because I didn't have the extension in the rear to swallow the hole.
Also, the drivers front would not ba as stuffed. Can't do anything about front extension however adding rear extension has been a big help. It aids in forcing the front down which stuffs the same side front and helps keep the opposite side front on the ground.
