Finally today I removed the whale tail spoiler from my LX470 2006.
It was faster than I expected, now I need to order the new center stop light and figure how to plug the holes.
I would like to get some Ideas to plug the holes, please. (if including pictures, better)
Yes I could go to the bodyshop but this will be my last option.
Here my 2cents to the MUD community
Some pictures and the FSM procedure (ET-8)
“1. DISCONNECT CABLE FROM NEGATIVE BATTERY TERMINAL
2. REMOVE REAR SPOILER
(a) Using a screwdriver, detach the 4 claws and remove the 2 rear spoiler covers
(b) Remove the 2 bolts.
(c) Put protective tape around the spoiler.
(d) Insert a piano wire between the vehicle body and spoiler.
(e) Tie objects that can serve as handles (for example, wooden blocks) to both wire ends.
(f) Pull the piano wire and scrape off the double-sided tape that holds the spoiler to the vehicle body.
(g) Slide the spoiler in the direction of the arrow and detach the 2 clips. (up and front direction)
(h) Disconnect the center stop light connector.
(i) Remove the spoiler.”
With mine, it was not necessary the piano wire (red lines), because the spoiler not was glued at all, I would suggest try to slide it, if it is glued, follow the above procedure.
It was necessary to remove the garnish of the back door, in order to remove the segment of wire between the spoiler and the main back door wire harness.
Parts needed
(1) 81570-60061 LAMP ASSY, center stop (high mount lamp)
(2) 90179-05011 high mount lamp grommet
(2) 90950-01865 high mount lamp clip
Tools
Socket 10mm
Phillips Screw drive
Teflon/plastic prybar (for trim and molding)
Parts needed
Tools
Socket 10mm
