I have the Slee Rear bumper and tire carrier. Great bumper. Slee also makes a bracket to move the camera to the tire to get a better view.
I liked the under the rear hatch lip location.
So I decided to move it along the lip to get a better view. I knew it wouldn't be completly clear, but much better.
Problem is I forgot to take a before picture, but suffice to say that at least half the view was covered by the tire
I could have used a jig saw, but I thought it would be cleaner to use a hole saw. I drilled two holes over lapping and then bent the middle lips in to provide room for the back bracket
I then re-routed the connector, drilled holes and screwed it down.
I then cut a piece of metal to cover the previous install hole and glued it on. Once it's dry, I'll tape up around it and hit it with paint
The view is not so bad anymore
