Some of you may have seen my thread about rebuilding two 8274 winches
https://forum.ih8mud.com/camping-gear-recovery/241652-just-another-8274-rebuild-lots-pics.html
and how the rebuild was interrupted by having to bail out of my garage to allow my home builder to replace the floor. The house is a two story with full basement and attached front garage. The house is 12 months old now and even when I took possession the garage floor was sinking in the middle. The floor was typical for around here with 4" thick pad, four 8" sonotube columns 6' deep, re-enforced with an 18 - 24" grid of rebar and the rebar drilled into the perimeter walls and driveway slab.
Two things in my opinion caused the slab to settle. 1) would be the lack of any real compaction of the soil/ gravel before pouring and B) would be the size. The water and sewer lines enter and exit the house under the garage and driveway. I believe this and concern about pushing out the foundation walls is why they don't use anything other than small vibrating tampers to compact the soil during construction. The size isn't huge - 22' x 26' - I call it two and a half car. But I would have put six support columns under it rather than four.
The floor had a 3" slope from the house to the driveway slab when it was poured to keep water running away from the basement. In August when I had the quality control guy in to inspect it there was enough settling to form a 4' x 10' standing puddle in the center of the floor 1/2" deep.
Now, we get a few snow dumps around here each winter usually in early spring and the garage is heated so there would basically be a puddle there all winter. Not acceptable. So my builder has replaced the floor and I am now watching it cure for four weeks before I paint it and move my schtuff back in.
So I thought I might bore you guys with some pics of curing concrete - it's much more entertaining than watching paint dry. Actually I have some fun planned. As stated above, I will be painting the floor. I'm going to use Jotunamastic two part epoxy industrial floor paint. It's leftover from work when we moved into the new bays and is very tough stuff - if a little slippery when wet. I'm gonna experiment with adding sand or something in high foot traffic areas to get more traction. I am also going to put up a 24" tall aluminum tread plate (diamond plate to some) baseboard around the perimeter to cover the foundation walls and make it look purdy. The tread plate is also surplus from work (I ain't made of money!). I'm doing the aluminum this weekend so will have some pics.
Here are three before pics from after I vacated the premises.
You can't really see the state of the floor in these shots
