Zero Point Calibration
Multiple alignments and tests, my body roll feeling never improved all these years. even after new MRA + King HD and TD UCA setup.
Scanned it, I found a C1268 code, so the shops or dealerships i went with this issue never did the zero point.
So I was able to finally do this Zero Point Calibration using Techstream today (for the yaw rate and G sensor), and yeah it transformed the experience! huge improvement in how it handles turns now, in terms of body roll.
Before, it always felt a bit off on corners, like the kdss system was reacting too early or too late. After the calibration, the steering and body control feel more natural and balanced, especially on sweeping roads.
Yay for Yaw!
Yay for Yaw!
I’m glad it helped, but whatever changed must have been outside the KDSS system. There aren’t any electronic controls in the 200-series version of KDSS, only a pressure sensor in the early years.
But again.. I’m glad the rig handles as you expect now…
You’re welcome! Yeah not sure what exactly changed, but the body roll feeling is gone now. Tested it on my usual hard turns and interchanges, feels almost as stable as it did back when it was stock height and suspension.
So I researched a bit more into this to know what/how it helped to reduce the body roll feeling. here is what i found, please correct me if i am wrong.
As we know, when I ran Zero Point Calibration, I reset the Yaw Rate Sensor and Lateral/Longitudinal G Sensors to tell the VSC computer this is what zero movement and level ground looks like.
If that calibration was off, even slightly, the VSC system thought the car was leaning, accelerating, or rotating when it wasn’t.
That false input made it apply small, unnecessary brake or throttle cuts mid-turn.
So, before calibration:
• VSC was subtly fighting my natural cornering.
• KDSS was doing its hydraulic anti-roll work correctly, but VSC was adding minor brake modulation at the wrong times.
• The result: car felt floaty or delayed, like extra body roll or instability.
After calibration:
• The VSC and ABS now read true zero and only intervene when the car actually leans or slides.
• KDSS still handles body roll mechanically, but now it’s not being counteracted by bad sensor data.
• I perceive this as less roll, but it’s really cleaner coordination between chassis balance and electronic stability logic.
So when I lifted my LC200, the new geometry changed the vehicle’s resting angle. That small tilt made the yaw/G sensor’s “zero” inaccurate.
VSC then misread the truck as leaning when it wasn’t, making it feel twitchy.
Once recalibrated, the ECU adapted to the new center of gravity and everything synced again.
But the weird thing is, most of my local LC community didn't encountered this issue. So that means the first garage messed something up while doing the suspension work, and it was never corrected all these years.? maybe that first garage had the ignition on or it was in a slightly tilted position while doing the work so it stored the wrong baseline.
After calibration:
All of that makes sense, especially the bit about VSC making small adjustments due to faulty data… and highlights how electromechanical modern vehicles are.
This makes me want to sort out my slight lean from worn springs and do a zero point cal to see if I can tell a difference.. thanks for the motivation.
You’re welcome, It was bugging the hell out of me all these years and scary as well on the dunes while side cresting.
I've seen this light come on a couple of times after I reverse out of my driveway..turn the wheel and give gas...flat residential concrete road..dry..
Could it be because of my car needing a ZPC?
Very well could be. After a wheel alignment it’s recommended to perform the ZPC. I have noticed the traction control kicking in much more aggressively and in situations like you experienced prior to performing the ZPC.
Oh ok. I have techtream so let me attempt a ZPC.
I did have alignment done in Feb.
