hey there,
I have a new to me 2H, just replaced cracked oil cooler housing and a couple of freeze plugs. Filled with oil and antifreeze and drove with good oil pressure for ten minutes. Parked and idled for ten more minutes. turned it off, cleaned shop. Tried to restart twenty minutes later, and engine would die after 4-5 seconds, would not idle. Determined EDIC shutting off engine due to lack of oil pressue. Confirmed with removal of sender unit; no oil. Pulled oil pan and pick-up screen was clogged, nasty sludge. cleaned pick-up, replaced filter and clean oil ... no pressure, zero. pulled pressure relief valve and cleaned, nothing. drained oil again, cleaneded all oil pickup tubes, pulled and cleaned filter housing and rotor on filter, blew air thru all passages, cleaned pump thru holes. put on pan, new filter, oil, nothing. Gotta be the pump, right? Gear drive off the crank. Has anyone seen one of these gear drive pumps fail so quckly? Could the sludge passed thru sytem with coolant mishap have been the final straw? The odometer reads 300KM, definitely had a rough life. I tried to prime it by loading oil thru pressure relief hole, no luck. tomorrow will try thru filter housing. any other ideas before I pull the whole front cover? Anyone know where I could find some new oil pump gears for a late '80 2H?
