YWST: Extended Anti-Inversion Shackles for the 8/1980+ 4x/5x/6x/7x Series Leaf Spring
cruiseroutfit
Supporting Vendor
Moderator
Utah
Website
cruiseroutfitters.com
Yeah - We Stock That! :cool:
Looking for a bit more height out of your existing suspension setup? These will bump your suspension height 5/8"-3/4" depending on your current shackle application. These offer a pin-to-pin height of 115mm (4.5"), which is 25-40mm taller than most stock and aftermarket shackle options. These have heavy duty 9.5mm zinc plated side plates and greasable shackle pins. These are built and zinc coated here in Utah and assembled @ Cruiser Outfitters.
For example, stock FJ60 front is 75mm pin-to-pin and stock FJ60 rear is 85mm pin-to-pin. Adding these will give you:
Front (115-75mm/2) = 20mm, so approx 3/4" of increased height on the front
Rear (115-85mm/2) = 15mm, so approx 5/8" of increased height on the rear
Have Old Man Emu or Dobinsons greasable anti-inversion shackles? Adding these will give you:
Front: (115-80mm/2) = 17.5mm, so approx 11/16" of increased height on the front
Rear: (115-90mm/2) = 12.5mm, so approx 1/2" of increased height on the rear
Sold as a PAIR (2) or a SET (4) as needed:
Part# SH60115FRPAIR - $95.00 (pair of 2, works for front or rear, LH and RH)
Part#
SH60115FRSET - $180.00 (set of 4, covers front and rear, LH and RH)
(I've been running them on the front of my HJ61 to level things up, I love the stance combined with the Old Man Emu springs and 92.5mm rear shackles)
Additional 18mm pin (8/1980 & later) Shackle Options:
OME GS1 - Old Man Emu Greasable Shackle Kit (Pair) - 90mm (3.5") Pin to Pin
OME GS2 - Old Man Emu Greasable Shackle Kit (Pair) - 80mm (3.125") Pin to Pin
SH35030 - Shackle - FJ55 - 85mm (3.375") Pin to Pin
SH35030G - Greasable Shackle - FJ55 - 85mm (3.375") Pin to Pin
SH60020 - Front Shackle - Non-Greasable (8/80-1/90 4x/6x/7x) - 75mm (3") Pin to Pin
SH60030G - Shackle - Greasable (8/80-1/90 4x/6x/7x) - 75mm (3") Pin to Pin
SH60050G - Shackle - Greasable (8/80-1/90 4x/5x/6x/7x) - 85mm (3.375") Pin to Pin
SH60050FAL - Front Anti-Inversion Shackle - LH (8/80-1/90 4x/6x/7x) - 80mm (3.125") Pin to Pin
SH60050FAR - Front Anti-Inversion Shackle - RH (8/80-1/90 4x/6x/7x) - 80mm (3.125") Pin to Pin
SH60050RAL - Rear Anti-Inversion Shackle - LH (8/80-1/90 4x/6x/7x) - 92.5mm (3.625") Pin to Pin
SH60050RAR - Rear Anti-Inversion Shackle - RH (8/80-1/90 4x/6x/7x) - 92.5mm (3.625") Pin to Pin
SH60080G - Shackle - Greasable (04483-60080) - 7x Rear - 90mm (3.5") Pin to Pin
Note: Use on front applications may necessitate caster shims post install, we offer shim pairs in 2 Degree aluminum, 2 Degree, 4 Degree, & 6 Degree steel options.
Subscribed.👍🎯👍
