Youtube Ideas (3 Viewers)
D'oh. That was supposed to go in for my clutch hose. I've replaced all the other hydraulic hoses on the truck so figured I should change that one too.
A couple of ideas for future videos, these are all pretty common job for the DIY guy. Love your videos.
  • 80 series Knuckle Job
  • HF2AV (Install Low range & High Range gear sets)
  • HF2AV - Install part time spool
  • Adjusting rear axle angle after suspension lift
It seems that the hardest part that folks have with a knuckle job is figuring out prooper preload on the wheel bearings and trunion bearings. If you spend some time discussing that, I assume it would be the highlight for most folks.
Thought of a few more Ryan:
1. Swapping Ujoints manually (without going to driveshaft shop).
2. Proper driveshaft greasing techniques.
3. Installing CDL and doing 7pin mod on 80 series trucks.
4. Timing belt/water pump job on a 1HZ/1HD-T/1HD-FT
  • A little more obscure...but how about a video showing how to wire up a magic dial to operate ARB's/Harrop's and have the dash lights work.
  • Maybe too basic...but for many it maybe quite useful. A video on how to change all your fluids (Coolant, Engine, Trans, Xfer case & Diffs) along with recommended products weights and service intervals.
  • 1FZ-FE - Solving typical oil leaks (Valve Cover, Dizzy O-ring, Oil Pump Cover, Crank Seal etc.)
Here's my contribution....
  • Shop Talk OEM Switch Install V2.pdf
How about a "Good wiring principles" video. Show how to build well protected and oranized 12/24V circuits.
