Here's how my sliders look like......
Nope. The U-shaped parts fit tight around the frame. Once fitted the clamps are closed and tightened with two bolts each.2 questions Ron
1 are they welded to the frame?
I 'tested' them in the field. First I tried them with a highjack. They did not move at all. Later they got tested during a trip to Russia ( see my webpage Ron and Yvonne in the Internet ) And they didn't budge at all.2 If they are not welded ,have you load tested them for slippage ,bending?
Neither did I. Apart from the risk of introducing stress to the chassis-metal when welding I wanted sliders I could remove fairly easy for whatever reason.The reason I ask is that I do not wish to weld or drill into the chassis and would like to use brackets/clamps if they are strong enough.
Hi Rosco
The most forward attachpoint is not a clamp but a plate that is bolted to the frame with the bolts that are originally there to attach the tranny/X-fer support.
Since then (three years now) all that happened to them where scratches, but no bending, dents or shifting on the frame.
The clamps fit very tight, I almost have to hammer them in place and then tightening the bolts on top fixes them as if they were welded.
I have to add that several of the U-clamps are on spots where originally something was bolted to the frame (clamps for fuel lines for example). At those spots I just drilled holes in the clamps and used longer than original bolts to refit those fuelline clamps.
Then, during the annual inspection, you can get problems because welding to the chassis has to be done by specialised welders and approved. This is simpler.
Thanks ,this will be the way I will do my 75 series![]()
Square or tube?![]()
Hay Ron thanks for the pics. I think I will do the same to mount mine. They almost look identical. Great minds think alike!
Ya box it is 2"x3" look identical to yours and the ones posted at the top I just tucked them under a little more. I will post up pics when finished if I can figure out how.
that was my concern also... in this truck both sides together weight 44kg-s. For LC70 I will make lighter tubing and i'm trying to manage keep in 30kg limit. If it not possible... i just make simplier square tubing too.I was about to do it the same way you did. Square box and tubing. But that adds a lot of weight and since my rig is also my daily driver I choose to lengthen the extension bars an just go for square.
I made first U-bolts from threaded bar (8,8) But bending made those very weak and fragile. So i decided to use backplates. Anyway, there is different possibilities... but one thing I never recommend is welding directly to frame. [/quote]I suppose you fix them to the frame by means of backing plates? I choosed to use U-shaped bolts to have a better clearance at the bottom.
